Hi, so I have got this dripping tap in my new flat, nothing serious but it drips from the spout and the base of the spout when off. Thought I could just replace the cartridges but when I pop the hot/cold dots off the taps and remove the retaining screws the taps will not budge, at all.
I'm a novice at this so I don't want to apply loads of force here and make any leaks worse but everything I see indicates once the screw is undone I should be able to just pull the tap off?
Am I missing something? (Also one tap is noticeably further away from the main body, this was like that since I moved in.)
