Like Nuclear and North Sea gas was going to be.I've often imagined how dumb we're going to feel when tidal or fusion or something else makes electricity so cheap
Well, as I recently wrote, our descendants are, somewhere down the line, going top have to somehow cope with a situation in which the accessible naturally-produced fossil fuels have all been used up.Like Nuclear and North Sea gas was going to be.
Even if we do, as I said "somewhere down the line" our descendants are going to face its ultimate exhaustion.Don't we have centuries worth of coal?
Back to town gas, eh? Not sure what my touchy-touchy condensing boiler will make of that.Don't we have centuries worth of coal?
Yes, the biggest trouble is with 12V LEDs. Unless you get the compatibility between dimmer, driver, and lamp exactly right then it may flicker, not dim smoothly, not dim at all, or not even light.
Mains voltage lamps are less trouble, but you can still have problems depending on the type of dimmer. The traditional leading edge dimmers have quite tight load requirements and one sized for traditional lamps probably won't work with LEDs. Trailing edge dimmers are often touted as the solution but are not necessarily better than a properly sized leading edge dimmer. Digital dimmers are the real answer, but that means a complete replacement with specialist lamps.
Sad, isn't it. I love LED lamps, but the difficulty (or expense) getting ones that dim reliably and properly is a real stumbling block at the moment.In the end I decided to scrap the dimmer switch and just get a regular non-dimming switch.
Looked into it and it was only going to get far too expensive.
I'd probably need to buy expensive dimmable LED bulbs that have the drivers built into them, or fit one into the light, started getting too complicated for a feature I don't really use.
Got a regular switch and now there is no more buzzing.
there is never any certainty that any particular dimmer will work satisfactorily with any particular LED lamp - so there is always an element of gambling involved.
