I'm having a problem with flickering lights on my dimmer switch tried new bulbs that are definitely dimmable and the problem is still the same. Any ideas could there be a fault with the switch itself and it's transformer?
And with the Transformer/Power Supply ?Is the dimmer compatible with LED bulbs ?
If it worked previously, with the same lamp,is it unlikely it could be anything wrong with the dimmer switch itself?
Thanks is it unlikely it could be anything wrong with the dimmer switch itself?
I'd buy another dimmer to swap in and test with. Best case, you identify what the culprit is, worst case you have a decent spare dimmer.Thanks is it unlikely it could be anything wrong with the dimmer switch itself?
Not sure if Tomsim knows if the dimmer causing the issue is compatible, but if he tests using a Varilight V-Pro LED (FYI, I'm nothing to do with the company), he can change the modes on it (leading edge, trailing edge etc) until he has a result that doesn't oscillate/flicker. He can then buy a dimmer that handles the approriate modes I guess. From what I gather all this stuff is a bit suck it and see to get the right combo.But do you know if the current dimmer is led compatible ?
Seemingly you don’t seem to want to answer this point
I'm not sure if it is would you be able to tell by seeing a picture of it?But do you know if the current dimmer is led compatible ?
You should be able to tell from the make/model number and looking up the specifications.I'm not sure if it is would you be able to tell by seeing a picture of it?
