Hey don't be offensive!
I was trying to point out the ambiguity of the wording in the Approved Document, which uses undefined terms and which makes Part P so useless.
Take a fridge or dishwasher a 'brown goods' integrated version usually has a tab which you screw to the underside of the work top, a 'white goods' version just sits under the work top with no attachment. One could be deemed fixed one not, both plug into the same socket both are electrically identical. Hence nonsense.
Same with the lighting a CE marked transformer and lights may come bare or with a mains plug (not the plug and socket connectors which daisy chain the things together). The approved document doesn't mention the mains plug just the connection point.
If I have a table lamp in my kitchen and I stick it down with some Blu-Tac to stop it moving does it become fixed and notifiable?
It is open to interpretation without greater definition of terms, which is what I was pointing out.
Some times a little common sense and pragmatism is required in the application of regulations.
