Bought two, two way dimmer switches, one with one switch, one with two
(after some research I've found you can't have two dimmer switches that control the same light so ignore the fact that they are dimmer switches it's really with the wiring i need help with)
below are images of the wiring in the light switches
* single switch, 2 red wires from 2 separate grey sleeves, yellow wire, blue wire and red wire coming from separate grey sleeve
View media item 39904
* double switch, 3 red wires from a seperate grey sleeve, yellow wire, blue wire, red wire from a seperate grey sleeve
* also note the little bit of red wire in my hand
View media item 39901
First off I wired up the single switch, worked fine, thought I was on to a winner. Wired up the double switch which worked, this resulted in the single switch not working. I decided to install the original single switch exactly the way that it was wired and now that doesn't work and neither does the double. So basically I now have two light switches which don't work.
*I made a note of all the wiring before I removed the switches and have put the cables back where they belong, I just don't understand why I have so many red wires when every diagram I have seen only ever shows one. Before I removed the old single switch the wiring went like this,
L1=Blue, L2=Yellow+2 Reds C=Red
the double switch went something like this (haven't got my notes)
L1=Blue+Red, L2=Yellow, C=Red L1=Red, L2=(nothing) C=Red
and then the little bit of red wire went from both C's
Any help would be most appreciated, I just can't get my head round it and obviously no diagrams help as they never show so many red wires
