Hi, my electrician has put in new recessed spots with one dimmer switch on one side of the room and a standard switch on the other side. If you turn the lights off at the dimmer switch and then turn them back on from the standard switch , the lights will only come on if when the dimmer switch was switched off with the lights on. If they had been dimmed and then switched off at the dimmer, when you switch them back on at the standard switch they do not come on . Is there something wrong with this - any ideas how to fix ??
Thanks !
Thanks !
