Hi, I'm installing some led strip/tape about 14 meters.. This needs to be dimmable but the switch line upto the dc driver is 230v as it would be as a normal switch line. The problem I have is that it appears that the LEDs which are 12v can only be dimmed on the load (12volt) side of the driver which would involve a lot of reconfiguring of the wiring as well as some ugly looking 12 volt dimmer unit. Is this normal with these tape like LEDs that the driver is not dimmable itself? The current switch I have have is an mk grid switch so was hoping to install a trailing edge dimmer like I have done in the past for led Downlights.
I haven't dimmed this led strip on any job as of yet so don't have much knowledge of this. Any help would be appreciated. Thanks
