Hello, we've just moved into a new house. The hot water system has secondary circulation. The pump has been installed without any control so it is on 24/7. I've never had a house with this set up before and wouldn't have thought it necessary given the size of the house.
At the moment the pump is noisy enough that you can hear it at night time in one of the bedrooms (it's in the loft just above). This may be due to the installation position as it is up against one of the beams. If we're not bothered by with the delay in hot water can I disable the secondary circulation by just removing power to the pump? Would I need to do anything else, is there something I should be aware of, is this not a good idea?
Any advice, much appreciated.
