It might be worth posting in the plasterers forum, its a quite active forum with pro guys contributing
https://www.plasterersforum.com
Thanks, good advice. The thought behind it was.... I've got a ceiling that getting worse with every coat/board that's put up and I've got 2 walls that have been overboarded and two walls that are the original plaster (some of these are cracked tbh too). So in order to get a A1 finish I think the walls will need to come off and if I'm getting a skip then I was thinking that bringing the 2 boards off the ceiling would also be a good idea. Let me know what you and others think. I know it's difficult to make a judgement without seeing it, so I know I'm asking a lot. I've got a plasterer coming to have a look today but having been burnt now I'm just trying to get an idea of a strategy for getting this sorted.
Thanks again.
take some pics so we can have a lookI know it's difficult to make a judgement without seeing it
Thanks again.
Taper edge boards were developed specifically for taping and jointing where only the joints are filled and sanded. For conventional skim work square edge boards are used - screw heads are sunk just beneath the surface whilst the scrim tape is far thinner than the 3mm or so of plaster which will be applied. Taper edge boards are also a bit weaker at the edge (because they are thinner) which is a decided disadvantage when overboarding a ceiling, I'd sayI said that I'd have thought that using tapered edged boards this would have helped. He told me he doesn't (and never does) use tapered boards he always uses square edged boards. I find this odd because I've thought that one of the points of the tapered boards was there to run the screws and take the scrim so it gives the ability to get a nice flat finish.
this is negligible and is countered buy the fact that you have more deeper plaster covering the scrimTaper edge boards are also a bit weaker at the edge (because they are thinner) which is a decided disadvantage when overboarding a ceiling, I'd say
I'm guessing that taking all walls back to block and pulling the ceiling down may well be the best option here
from where im sitting it looks like a half decent job as i said earlier ceiling lines can be leveled out with some easifill thats not to bad at all tbf to start talking about overboarding of pulling it down is crazy the line is out by a fraction and hardly noticeable i reckon you have been to harsh on the spread
