Hi anyone !
Had the above problem with our dishwasher last night and couldn't get a concrete solution from the various threads so thought I'd post what worked (albeit a temporary fix) for me.
Dishwasher was fine until last night, started a cycle as normal but only a few minutes in started beeping continuously, then drained and when it had stopped completely showed an error code by flashing the light next to the diamond labelled button 11 times, pausing and then repeating.
Tried cleaning the middle bottom filter and related components, but it still did the same thing. Turned the power off, took the front metal panel off at the bottom, to find that the tray was full of water. Noticed there is a circular black plastic piece attached to the tray behind the bit of the filter housing that projects down into this space. It appeared that inside the black plastic there was a disc of polystyrene which becuase of the water had risen to the top of the little black plastic cage. There are two wires coming off the cage housing also, so thought it might be a sensor to detect when the tray was full as the poly would obviously float upwards. Drained the tray using a towel and kitchen roll until dry (again make sure power is off at the wall first). Tried the dishwasher cycle again and it's absolutely fine )
Obviously this doesn't address where the water was coming from (which I couldn;t find any evidence of) but I'm hoping it's a very slow leak from somewhere and will only need the above process repeating maybe every 3 months or so - better than no dishwasher.
Hope this helps someone.
