The default distance flue-opening is 300 mm, what is the default distance flue to brickwork/windowframe, was it also called builders opening?, and how do you measure it? heart to heart? Inner pipe (actual flue) to opening or outside pipe (in fact the airduct) to opening?
Some say it is 150 mm and others think it is 200 mm.
I think the one in the picture might be a little bit close.
