Eh?I dont think Ive come across any builder doing strip footings for extensions of any size
By strip footing, I mean a strip of concrete in the bottom of the trench and building up in blockwork.
A perfectly valid way, but up here (beyond the pale to southerners!) builders prefer just a 150-200 thick concrete strip and then trench blocks to just below ground level. Suppose it's down to cost/speed etc.By strip footing, I mean a strip of concrete in the bottom of the trench and building up in blockwork.
Builders seem to mass fill the trench leaving only a block and brick course below ground level.
Deep trench fill concrete foundations aren't the norm around here in Yorkshire either, 600 x 225mm concrete strip foundations would always be specified for external cavity walls unless the engineer specified otherwise to suit ground conditions. 450mm wide ok for internal 100mm thick blockwork walls , but a housebuilder I worked for didn't even want to reduce the width for internal walls because they said it wasn't worth changing the bucket on the JCB when digging the trenches !Builders seem to mass fill the trench leaving only a block and brick course below ground level.
that surprises me even more. what about extra cost of concrete with trench filled foundationsThat does surprise me, Ive honestly only seen strip footings in a textbook!
not since Fred Dibnah diedDo they excavate with a steam shovel and bring the concrete on a cart?
V's buying the blocks, sand, cement, lugging them around a slippery trench, clambering round with a level and a trowel in mud and muck and often rain and the hours of back breaking expensive labour....what about extra cost of concrete with trench filled foundations
Pussy. Get in there and get your head down.V's buying the blocks, sand, cement, lugging them around a slippery trench, clambering round with a level and a trowel in mud and muck and often rain and the hours of back breaking expensive labour....
Now you're talking Woods.Pussy. Get in there and get your head down
...when all you need is a few extra seconds with the pump truck and a couple of hundred quid. We haven't used strip footings for decades. They became obsolete when concrete pumps and volumetric mixer lorries became widely available.
And you still need a bit of gear to fill the cavities to within 225mm of DPC.The only frustrating thing is always having to do foundations, and concrete slab as separate pours needing 2 pump hires.
Well, as you know we're all thick up here . I'm amazed anybody is amazed about using strip foundations, it really is the normal specification around here for foundations unless ground conditions dictate otherwise.Im amazed that up in Yorkshire they do strip foundations.
