Hi
I read somewhere about diversity, where someone had an induction hob and his electric oven plugged into a double socket which was fed from his cooker plate (the dedicated cooked circuit from his CU). Even though the theoretical total AMPS was way above the 30A of the circuit, because of "diversity" this would be fine.
Is this correct?
I have an induction hob to install, rated at 6.6kw (about 29 amps) and also an oven, rated at 2.15kw (about 10 amps)
At the moment, I have a double socket in one of the kitchen cupboard which the oven is plugged into along with the current gas hob (for the electric igniter).
Any advice would be greatly appreciated.
Thank you.
Is this correct?
Thank you.
