DIY Consumer Unit Change
I think we all know there are two ways of pricing a CU change.
1) A high initial cost, but likely to be an honest quote that won't later increase.
2) A cheap initial cost £300, and various extra's will (or could) be added along the way.
Indeed - and, provided the 'extras' are charged fairly (which often they are not, by the £300 folk!!), the latter would probably be the best for the customer, because they then pay for the work which was actually required. The former approach (if it's a 'fixed' quote) inevitably means that, if the job proves to be very straightforward, the customer will usually over-pay, since the high fixed quote will have incorporated some provision for 'extra work which might have been required'.
Kind Regards, John
^thats right.
The question is, leave the earthing and that will £400 max or DIY the earth and they will hunt until they find something else wrong.
It's the unknown unknown costs that is the concern.
E.g shared neutral on landing light.
You might want to investigate that first and resolve if required. That would be expensive.
A simple example of that is singles at the landing switch, however I think its an intermediate
The classic example is the landing light stops working when the downstairs fuse is removed.
Or a link between the com terminals in the downstairs light switch
There appears to only be 1 lighting circuit so no issues now. I will pull the cover off the board and have a peek. I have 30-40mtrs of old skool B&W T&E which if I could find where upstairs is fed from and JB it out back the board.
Oh yes I recall now. I would be using a type C MCB for the lights then.
Don't want a blown bulb leaving the house in darkness
I know that feeling however most people can walk from memory and we have good corridor husbandry of keeping it clear
Some images
Board and Meter inside a corner kitchen cupboard.
Post deleted as photo posted below.
Double Socket, Spurred from a Single Socket, Providing power to the garage board and the light in the rear porch.
Awesome eh
Tissues not needed with left to right gravity.
Why are so many pictures rotated lately?
Can't all be the posters.
We also found Choc-Blocks on 1mm in the attic with tape on them, easy fix.
Here are the pictures rotated..
Ah...the fridge socket?
EFI... just for you.. a screen shot.. photos were uploaded using phone.
FTB
It's a well-known (should be well known to Apple users) problem with images from iphones (and probably ipads too).
http://iphonephotographyschool.com/iphone-photos-upside-down/
But whatever the root cause, and whoever is to blame for the orientation ending up wrong, it is the posters fault if they don't, immediately after posting, think "oo-err", and use any of the many image processing tools out there to fix it and re-upload.
That link is regarding photos being 180° out. Where as the OP's photos were 90° out.
