Hi
New to the forum, i am looking at wiring up a lamp using an old Jerry Can and i am unsure on how to go about it.
I assume being metal it will need to be earthed which will need 3 core cable. I can wire a plug etc no bother so i have no issue with that but i just want to make sure this would pass a pat test etc to be nice and safe.
I plan on using a metal lamp fitting to keep in the style.
The other option would be to reduce to a 12v circuit and run LED's from a bulb or strip? I assumer the low voltage would no longer need a earth. Any simplified suggestions? Thanks.
