I'm afraid you've just proved that common sense is misnamed.
Maybe. However, speaking personally, if I had a need for an 'insulator' to provide electrical 'insulation' then, quite apart from any regulations and Standards, I would have a fairly good idea in my mind of the 'performance requirement' (in relation to electrical insulation) needed/wanted for my purpose, and I doubt that materials that were deliberately made to be significantly conductive would satisfy that requirement.I'm afraid you've just proved that common sense is misnamed.
Exactly - and, despite that, I would have pretty good idea of the minimum 'performance requirement' for my purpose. That was really my point in talking about myself.But you're not an electrical engineer.
It would obviously depend upon many factors, particularly the actual situation in question and the reason that insulation was needed. The second question is really a no-brainer - my requirement would obviously be for it not to be "significantly conductive" at a voltage at least somewhat above the highest voltage to which it could be subjected in service. The question of what I would regard as "significantly conductive" really would depend on the application - but I might well look for guidance to what the Standards for electrical cables etc. deem to be adequate for the insulation of live cores at the voltage in question.Would you care to quantify "significantly conductive", or specify a resistivity, or even a voltage at which the conductivity was "significant"?
Maybe you should get some more stock in - this isn't the first time we've had this discussion (inevitably started by someone complaining about the 'incorrect' mention of "double-insulated cables"), and I doubt that it will be the last!I've run out of popcorn...
Yes, in relation to this issue, it's more often than not Risteard who takes people to task.Yes, I'm guilty of calling them DI cables, but I do get shot down, often by Risteard...
If sheathing was required to pass the tests for insulation, why would it be called sheathing and not insulation?The argument here seems to be all about whether sheathing is 'required' to qualify as 'insulation'
Perhaps because, as I have suggested, even if it were required to pass tests in relation to insulation (as you are aware, I don't know), to be acceptable as sheathing (rather than 'just insulation') it is possible that it might also have to comply with additional requirements as regards other physical properties. In other words, it's not impossible (again, I just don't know) that what we use as sheathing would be acceptable as insulation, but not necessarily vice versa.If sheathing was required to pass the tests for insulation, why would it be called sheathing and not insulation?
Many thanks.OK, I'll see if I can access a copy. Watch this space.
I wouldn't know. All I can tell you is what I have already said - that the 'insulated and sheathed' single-core cables I looked at said that the sheaths were to BS EN 50363-3. Whether that Standard has a lesser or greater requirement than BS 6004, I haven't got a clue.I thought BS6004 would be the most appropriate.
Indeed. There's obviously nothing preventing any manufacturer of anything making a product which exceeds the requirements of relevant Standard(s). That's why I had the two questions. Even if you discover that the Standards do not require the sheathing to have demonstrated insulating properties, that would not necessarily mean that none of the products out there have sheaths that would qualify as 'insulation'.There's nothing to prevent Prysmian exceeding the requirements of a standard.
