ask away happy to help
to the front storage area I have 100mm kingspan/celotex then silver foilHi
What insulation did you use for the rafters.
As spec'd by building controlDid you consider using quilt such as Actis Tri iso.
I think i have similar, all interlinkedI have a 7x2 ridge board. I persume you had similar. How did you strengthen it without the use of steel or lossing headroom.
Mine was connected front to rear on each rafter as it hung out the rear formed the flat roof joists, BR spec'd Dia 75mm timber connectors that are a bugger to get but have a load left now.Did you brace each rafter at the apex just below the ridge board.
I merged 2 ways.What size timber did you use for the cheek walls.
yes if lime plaster you will need to chicken wire in the RockwallDid you put a 20mm spacer between the roof plate and new joist to avoid snagging the lime plater etc.
Thanks in advance. Simon
There is little if any advantage in using Tri iso, it needs a gap above and below, removing any perceived space savings and it ain't cheap.Did you consider using quilt such as Actis Tri iso.
