ok. when your testing your Ze you test between p&e right. Inside the cut-out there is a neutral block and also an earth block. These two blocks are connected together by use of a copper bar. I've checked google for images but can't seem to find any. This is what i mean by testing to neutral. Your neutral is your earth on a pme system
It doesn't prove anything. Neutral and earth are linked at the sub, so you could easily get a reasonably low reading between N and E with, say, a TN-S supply. I also don't see how you would test 'Ze' between N and E - are you sure you don't just mean continuity on low ohms range?
