I need to put a new surface on part of a wall that is full of scrathes etc and a few small bits of artex but do not want to use bonding as it will bring it out to far with multifinish ontop and will then have issues with the staight edge of a kitchen work surface unless i do the whole wall which is 4 metres and mess with window corners etc .
As there is nothing deep to fill can i use multifinish and pva to get it to stick
Basically will muli finish stick to old plaster with a little bit of paint on it
Friend said mix a bit of bonding with the multi but dont knowif you can
