- Joined
- 2 Dec 2004
- Messages
- 550
- Reaction score
- 4
- Country
Ie, the valve can be within the thermal envelope of the building, and some normally empty pipe can be the external bit.
How would I ever access it if it's under the floor?
I would more comment on the airbrick being below a door rather than a drain off that is run through it. May also find the airbrick was there before the door was, so maybe the door shouldn't have been placed above an airbrick or the airbrick moved when the door was put in, maybe that was the original lack of though. When the door was created why wasn't there a step created then too, maybe that wasn't in the design or purpose?And putting this drain under a door frame, exactly where a person might want a step is just a lack of thought.
A marked removeable floor board.How would I ever access it if it's under the floor?
It has been explained that this is standard practice when it comes to CH setting out- with some new builds they have concrete slabs foundations, so it's not possible to have any pipework under the floor therefore no external drain off's.
You're obviously not in agreement with the responses - though at the end of the day it's totally your choice - it's your house and it's not a legal requirement to have drain off points.
It has been explained that this is standard practice when it comes to CH setting out- with some new builds they have concrete slabs foundations, so it's not possible to have any pipework under the floor therefore no external drain off's. In other builds with floating floors then this is still the standard. I drained and flushed a CH system not 2 weeks ago that had 2 drain offs out of an airbrick. Property is a new build, only 4 years old
Anyway, it really is up to you - knock yourself out.
Yes, again, perfectly normal.I can kind of understand why this was done in the past but it's not done in modern builds/modern systems is it?
I think you've just answered your own question about what the purpose is of such a drain point!I can possibly relocate the drain to the left of where I want the step, but I'd have to drain the whole system to do it.
