depending on the boiler make you could add a proprietary controller and an out door sensor...this varys the flow temperature through out the day matching heat generated to heat required, as opposed to running the whole thing too hot waiting for the TRVs and two ports to shut down
Also I was thinking of putting the room stat in the living room/dining room as this is the main room used obviously as opposed to the hall were it was in our last house. I would then allow the rad stats to control the other less used rooms. The thinking is if the lounge was up to temp and shut off the boiler when other rooms werent quite warm enough this wouldnt be such a big deal.
Would there be any issue having a room stat in the room where the two rads there also have rad stats?
We also have a solid fuel fire in the lounge which we use all the time.
You negate a lot of the advantage of a zoned system not controlling it with thermostats the best solution really is to fit a thermostat in a sensible place to control each valve. You already have separate timing control for each zone which is good.
