That's not quite how lighting circuits work
Some examples here...
Examples of the most commonly used UK lighting circuit diagrams
flameport.com
As above, the brown wiring you currently have is correct.
It is becoming more common for neutrals to be looped into the switch back box. This gives you the opportunity later on, to install items such as smart switches, that may require a neutral.
However, given the state of your wiring, we can not even say that those wires are neutrals - all we can say with confidence, is that they are blue!
It would be acceptable to fix all three blue wires into a separate terminal block. Simply twisting the wires together, is not an adequate way to maintain continuity of the circuit.
The fixes should be a simple DIY task , if you are up for it.
