All the ones I have removed have been due to going faulty, all Honeywell CM67's, all with exactly the same fault.
Now don't bother.
Easier life.
The cheapest I have found online is over £40.
Who did you buy it from?I dont think you looked very hard!The cheapest I have found online is over £40.
This one is £14 + VAT if you buy 100 or £20 + VAT if you just get one! Note the batters is shown as non replaceable but I would aim to get inside and sort that out!
The one I use is a USB-501-LT by Measurement Computing.
Now don't bother.
Easier life.
whats the fault dave? i've been changing a few Dt90s lately with faulty relays, wondered if its same problem?
Now don't bother.
Easier life.
Every single one would not bring the heating on first thing in the morning.
Every other on and off command worked fine
It always seemed to happen after about 4 months or so.
Intereresting info, but it does not answer my question.I obtained mine directly from the promoters as an evaluation sample to determine its usefulness in setting up heating and weather compensation systems. But the listed one is cheaper.
Did you ever get round to deploying this test? If so, any findings to report..?I will report my findings when the heating goes on.
Anyone who cares about their house being at a certain temp at a certain time will get to know their system and time the programmer as such. The difference in different temp environments in domestic premises is negligable (it might take 20mins longer when its really cold---big deal). I can imagine in a very large house or commercial premises it makes more sense.
Yes. The test has been running since 17 September. On times definitely vary with outside temperature - though I have not got a definite relationship. The minimum I have seen is 15 minutes and the maximum two hours in the current weather. I don't have data for every day, as sometimes I forget to turn the timer on when I go to bed.Did you ever get round to deploying this test? If so, any findings to report?I will report my findings when the heating goes on.
I seem to recall that's the maximum it'll do, compared with the previous CM67 which could come on upto 3hrs prior.maximum two hours in the current weather
I've never checked this as I don't feel like getting up at 0530 to see if the house is up to temperature.Specifically, it seemed to reach target temperature way too early - nearly an hour in once case I seem to recall.
I know the stat "learns" when to come on, but I'm not sure if this is a one off task or a continuous learning process. Is there any way of telling the stat to start again, for example after you have installed insulation?I can accept it can't be perfect but that was pushing it a bit. To be fair, the testing was far from structured and so it could well have been the case that there was some other factor at play e.g. several days of the house being cold due to fitting windows, or the boiler being out of action due to plumbing works but me not 'telling the stat'. Both cases could lead to the stat thinking the heat-up times were significantly longer than reality.
I must say that I am surprised that it takes 2 hours to heat the house each morning as the house is very well insulated (filled cavity walls, 270mm in loft and DG windows), the internal temperature only drops about 5 or 6 degrees overnight (stat set to 5C overnight), and the rads and boiler are now massively oversized for the heat loss.I seem to recall that's the maximum it'll do, compared with the previous CM67 which could come on up to 3hrs prior.maximum two hours in the current weather
Indeed. I seem to recall I caught by just happening to be nipping to the loo at that time.I've never checked this as I don't feel like getting up at 0530 to see if the house is up to temperature.
I think it would have to be continuous otherwise there would be a very real risk of it being incorrect if it was a one-off and, as you mention, there's no readily available (documented) means to make it re-learn.I know the stat "learns" when to come on, but I'm not sure if this is a one off task or a continuous learning process.
Could it be that yours too went a bit overboard and ended up reaching target temp way too early? It would certainly correlate with my findings (notwithstanding by limited testing as previously mentioned).I must say that I am surprised that it takes 2 hours to heat the house each morning as the house is very well insulated (filled cavity walls, 270mm in loft and DG windows), the internal temperature only drops about 5 or 6 degrees overnight (stat set to 5C overnight), and the rads and boiler are now massively oversized for the heat loss.
