- Joined
- 13 Dec 2007
- Messages
- 106
- Reaction score
- 0
- Country
DONT!!!!
They work loose over time especially if a fair amount of current has gone through them due to expansion/contraction (heating/cooling) and can overheat/catch fire! Using them on stranded conductors is fine, even better if the cable is more flexible (like tri-rated switchgear wire) but if its solid copper, use choc blocks and remember to double the conductor over .
You may find that DNO installation inspectors will fail an installation and refuse to connect a meter should they suspect an installation uses crimps like this.
If you have to put lugs on to solid conductors, use solder and heatshrink. Might be more time consuming but certainly improves the quality of work done.
Note: This advice applies to the small red/yellow/blue crimps used on smaller conductors, the larger ones are fine as the crimp is much more secure.
