Bodge = A clumsy, messy, inelegant or inadequate solution to a problem
Personally, I would never use the above method to make a permanent joint even as a last resort. The joints always look clumsy & messy even when done well. Also, I would never joint T&E and then plaster over it. I suppose it boils down to how you've been taught.
It's a bit like running cables outside of the safe zones. Although you can do it I've never come across a situation where that was the only solution.
