Hi everybody,
I have recently had an electrician in to give me a quote and Im not sure I trust what he's saying, Id like to see what you all think...
Im looking to put an electric shower in my bathroom. I think there used to be one as there because there is already wiring hooked up. I got a guy in to tell me if I could re-use this existing wiring, and if so what shower (max kw) could I put in. He told me the cable is only 10mm2 and would need to be upgraded and put on the outside of the wall in order for me to fit any 'normal' shower (7.5kw and up), also the MCB would need upgrading. He quoted £260 to run the new cable and upgrade the MCB.
Now Ive looked at everything and these are the details: The consumer unit is wylex with a 40A MCB for the dedicated shower circuit, I believe the cable is 10mm2 (based on what I can see) and is around 15m long, The shower cut off switch is rated 50A (I took it off the wall and checked), and the cable runs under the floorboards and up inside a plasterboard wall (not insulated). I think the voltage in my house is 240V (that's what it says on the meter).
I know from school that 240V * 40A = 9600kw. So even given voltage drops and changes in voltage at the supply I believe I should be ok to fit up to 9kw shower?!
Im really not sure about what he tells me, also I really dont want the cable on the outside of the wall?!
Sorry about the long post guys, but what do you think? Any help appreciated.
