Hope someone can help. I have a conservatory which has two 2-gang sockets in in. The wires go through the wall into the house and attach to a standard 2-gang socket in the downstairs ring main (unfused). So a spur.
I have a mains powered light that is also in the consrvatory mounted to the wall. The wires from that disappear into the floor and used to pop up next to the first 2-gang socket and was plugged in.
I have now tiled the conservatory so have cut off the plug from the light and poked the wire into the first 2-gang socket box. I now need to connect it within the box.
I could connect it to the terminals inside the socket but then it would be unfused, so I believe I need a FCU to act in place of a plug but since it is a 2-gang socket, I have been looking for a new socket that has an FCU on one side to connect the light so it is fused and to leave a normal socket on the other half.
Does such an item exist. I've searched everywhere!!
Thanks Nigel
Thanks Nigel
