- Joined
- 27 Jan 2008
- Messages
- 25,296
- Reaction score
- 2,957
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It does confuse me, the problem is until you buy and fit a device one is not sure what it will do. However to me whole point of having eTRV heads is that each room is individually regulated, some have no electrical connection with the boiler, the only connection is through the temperature of the return water, however most do report the set and current temperature so actually do transmit what is required to switch boiler on and off.
The big question is how to connect the boiler to the eTRV head? Some have it all ready made like the EvoHome however even EvoHome has a thermostat option, not really sure why? Others need some device to actually do the switching, theory it could be a simple relay, and there is no reason why an IFTTT app could not be written to switch on a relay when any valve head shows a target above actual temperature.
However as far as I can see for the app to work, the internet also needs to be up and running, this is one of those bits where not sure what happens? But it does seem the apps are on a central server, so no internet and no app. As to connection between Nest or Hive and the eTRV head, this also seems to use the IFTTT system so again no internet and no hand shaking.
Even with hand shaking, it seems either Nest or Hive follows the eTRV head, or the eTRV head follows Nest or Hive, but the whole idea is that each room is individually controlled.
I had every intention of fitting nest, however now I simply can't see how it will help? Yes I want something to turn off all heating at night, or at least reduce the temperature to a low setting. As it stands I have two options for the non eTRV head controlled areas, I have a programmer which can turn off the thermostat in the hall, and I have a programmable thermostat on the oven carcase in kitchen which can also switch heating on and off, used as a frost stat in the main. Although the kitchen thermostat is useless when the oven is in use, Christmas day is only time over used over night so not really a problem.
So I simply can't see how adding extra hardware will help me? OK the nest should learn, but really how does that help? the existing thermostat in the hall is there for one thing, to turn off central heating when the weather gets warm, it is simply there to stop house getting too hot, it does NOT control the temperature of any room, including the hall, that is controlled by the TRV on the hall radiator. All the thermostat does is switch off the central heating in the summer.
Even that is not really needed, it could be a simple on/off switch, when summer comes I don't want the central heating firing up, even on the odd cool day, temperature is controlled by opening or closing windows, I don't want a cold draft starting the central heating, it's switched off.
So since the thermostat does so little, why get any special one?
