crafty1289 said:a quick note here. we had a BROWN 100A wylex board with a wooden back. how rare is that???
Adam_151 said:I can't see why not, nothing wrong with crimping an extension on cables in a fuseboard as long as its done properly, unless anyone can come up with a reason why pyro cores can't be crimped for some reason I've overlooked or some things
The Jeep said:I know it's correct practice to put the highest rated MCB nearest to the main switch, but does it really make any difference? I thought it was just anal good practice!
By the way, I feel confident that the main incomer can take the additional load of adding a shower, as it's protected by a 60A HBC fuse downstream, which I believe can handle a lot more current than that over short periods (any opinions on that?).
Ultimately, its main function is protecting the pyro incomer and cables up to the CU from overcurrent and therefore overheating. If the total current draw in the flat is too great, that fuse would blow (no built-in protection on the main switch on this old board), and as long as I don't change the rating of that fuse, then the level of protection is not compromised.
do I determine if the old fuse board (probably 1960s) is up to taking, say, a 40-50A rewirable fuse? I'm pretty sure you do get them with those higher ratings, so what would be the limitation? The bus bar?
The Jeep said:But how do I determine if the old fuse board (probably 1960s) is up to taking, say, a 40-50A rewirable fuse? I'm pretty sure you do get them with those higher ratings, so what would be the limitation? The bus bar?
RF Lighting said:You need to look at how much load is currently running of this baord, and the maximum current rating of the board. If you overload the board them you risk burning out the main switch or busbar, and although it is rare, it does happen. I've seen it and it scary how close to a full blown fire that house had.
An alert homeowner saved the day and nearly killed themselves in the process, but thats another story.
plugwash said:but i agree anything that your using wet and naked and is liable to be sprayed with water should be RCD protected.
WabbitPoo said:plugwash said:but i agree anything that your using wet and naked and is liable to be sprayed with water should be RCD protected.
Does that include the wife?
