- Joined
- 11 Jan 2004
- Messages
- 44,605
- Reaction score
- 3,069
- Country
Just wondered, there may have been a reason.
Maybe not, but better informed.so I am non the wiser!
Getting back on topic:I live in Croatia but own a small cottage in Scotland that I rent out. My Landlord Registration is due for renewal soon and I have to provide various documents including an electrical safety report. I got an electrician to inspect the property but he has found various defects. His estimate for rectifying these is £1650 including VAT. A big chunk of that is for renewing 3 consumer units. There is one for the main house, one in the garage and one in an attached outbuilding which houses the gas boiler. The one in the garage is a purpose made Screwfix garage CU with RCD and MCBs for lights and sockets. He says that should have a metal enclosure and the RCD and MCBs should be the same make (one MCB is Volex, I think the rest is Protek). The other 2 are older and I think are still fuseboxes, with no RCD. He says RCD protection is required because of regulation 522.6.202/203. This regulation concerns cables behind plaster, panelling or whatever. Has this regulation been applied retrospectively, to old installations? If so, it implies that every home with no RCD protection is deemed unsatisfactory.
I did that, the cable was not following a safe route, even with RCD protection, I was knocked out, I likely became disconnected in less than 40 mS so the RCD afforded no protection at all.The regulation quoted is so if anyone drills into a cable they can't see or is immediately obvious the circuit has RCD protection to avoid electrocution, someone did that who was related to a politician and that's how all this started to avoid another death.
Not sure, I know there was a problem with bus bars, where some tightened down, and tightened up, so it seemed as if all nice and tight, but really was not. Result could be over heating and fire. There was also a problem with some, where the tongue on the bus bar could end up wrong side of the terminal clamp, so just lightly pressed against the bus bar, not clamped.Mix and max MCB = C3 unless the odd one(s) have been butchered in and / or have any form of damage
