I think Part P is a bit bizzare, it because it dosn't allow you do things like put an alarm wire in a bathroom (I can't see how that would cause problems) on the other hand as far as I am aware you it does allow you to add an extra socket spur from a ring?
From my limited knowledge you have to test that the spur you want to make is not already final circuit, or indeed another spur, you need to use the correct cable and then test that its all safe and that the earth is good enough.
I have an ethernet cable under the end of the bathroom floor (it was the easiest route) and it seems this is ilegal?
So it seems they may as well just go the entire hog and say unless you have xx qualifications you are not even allowed to wire a plug!
