says who??It does raise the question why a bypass is not required for a 3port valve
I always stick two lockshields on the rad in the room where the roomstat is anyway, saves the bother.well I recommend you should
How is the beard coming?Hey you ive been giving ben stick today pick on him tomorrow
fitting 2 lockshields may save the bother but isnt as good as an auto bypass re the pressure increase and differential flow as per my post.I always stick two lockshields on the rad in the room where the roomstat is anyway, saves the bother.well I recommend you should
That is why I stick 2 lockshields on the rad in the room with the roomstat, regardless of the system used.Eh on a mid position valve you do get CH only when selected
if you are right i stand corrected, but what is then the diff between a mid position valve and 2x 2 ports, i always thought a mid position valve was as i described and never closed fully to hot waterEh on a mid position valve you do get CH only when selected
