doglegs in wiring...help
30 Aug 2007
installing an extractor fan in a utility room (no sink in there). I want to spur horizontally from an existing wall socket (unspurred as yet) to an FCU. Then go vertical from the FCU, then dogleg a right angle to a flex outlet plate for the extractor. If the dogleg is within 15cm of the ceiling, do I need to show where the right angle occurs using say another flex outlet plate or can I just bend the cable at right angles take it horizontally to the extractor?
I am going to use plastic conduit clipped at a few points to the wooden battens behind the plasterboard (this ok too?, are clips required or can cable hang in the space behind plasterboard?)
If I do need to show where the right angle is with a device, what do I use? another flex outlet plate and patress box as said or something else?
what would be required if the dogleg wasnt within 15cm of ceiling?
You don't need to indicate the position of the bend, because the 'safe' zones extend horizontally and vertically from each accessory.
You need to clip the cable at least often enough to ensure it stays within the safe zones.
