That was a matter the local council would have been interested in.He was running a business from a domestic property.
The DNO were only interested in the disturbance his equipment was causing to the voltage on the local supply network.
The DNO could not have cared less that he was running a business, all they cared about was what he was doing to the supply. If he'd been running a business and not been causing problems they would have left him alone.
If he had been a non-business person with a ceramics hobby who had a large kiln that was causing problems they would have shut him down.
Did you actually read any of the other topic?Rubbish.
The complaints were made to the various electricity supply companies ( and maybe directly to the DNO ) about lights flickering and other indications of voltage fluctuations. As far as I know no-one complained or mentioned the business operation.[If he wasn't running a business the people around him wouldn't have complained.
1) Yes they would. Their lights weren't flickering because he was running a business, they were flickering because he was using too much electricity.If he wasn't running a business the people around him wouldn't have complained.
Maybe because such a warning might put some people off, and hence reduce their sales/profit?Why don't they carry a Warning to the user of this problem, if it is a problem.
If you buy bricks and sand and cement, do you get warned about Building Regulations and planning laws?Why don't they carry a Warning to the user of this problem, if it is a problem.
When buying a car, have you ever been 'warned' by the seller that you would need to have a valid driving licence in order to be allowed to drive it?
Kind Regards, John
I doubt that there often are problems/issues associated with ignoring the contractual requirement to get DNO permission to use such equipment - not the least because the average DIYer/hobbiest is only very rarely going to use the items, and usually only for short periods.I think if it was a common problem/issue then they would have, however given how rare it is I guess its not even an issue.
However, as BAS and I have both suggested, even if the problems associated with use of such equipment were common, I don't think it's down to the supplier to issue warnings - and we've both pointed out (with just two examples, put of countless possibles), there are countless examples of things which are sold, the use of which is associated with legal and/or contractual requirements or constraints, but you'll only rarely find the manufacturers or sellers issuing warnings about this.
Kind Regards, John
I think you'd have to ask your own DNO.In a similar vein, is there a list of items that you don't need to contact the DNO to use?
aesmith";p="3269207 said:Regarding the original question, if the welder worked OK on an older installation with 30A fuse then it is possible it will trip a 32A MCB. .
The original question was would I have to change the 32amp breaker in the new board using a domestic Arc welder.
It worked OK via a 13amp plug fuse and 30amp board fuse in the old board and have since used it for a repair job still with the 13amp plug fuse and B32amp breaker in the new board with no problems.
I think its time this thread was put to bed where its getting above most peoples head.
thanks
No mention of it being a domestic welderfirst post said:Since change my old domestic fuse board for a Circuit breaker board some 2 years ago I have not used my 140amp Arc welding set.
