I assume you feel the need for emergency lighting because youve done a bodged wiring job in your own houses using dual main rcd boards.
Thats one of the reasons they do not comply with the regs, but they are a bodgers delight.
And now you bodgers are installing and paying for emergency lights instead of individual rcbo's as called for in the regs.
If the wiring was done properly, and you're that nervous, all you need is some plug in night lights.
And I can assure you that even the most sophisticated systems are not designed for two simultaeneous faults/problems - because they don't happen.
So RF, sparkyspike, graham, eric and malatron are all bodgers in holmslaw's eyes.....
Did you use a std 11w fitting or did you use the packs you can hide away and connect to your existing fittings??
Can you give us more info on that? Have you got regular interlinked alarms, or a fire alarm system with a panel?I've also linked them into my smoke alarms which will switch them onto maintained mode should they ever detect smoke.
RF - Whats your thinking behind linking the EM lights to your smoke detectors?
If the power is on the lights will work via the switch and if not the EM's will come on anyway?
I’ve got a torch
Would she not understand the risk of being shut in the cellar, with nobody able to hear her cries for help, and how that risk might increase if she keeps turning the lights off when you're down there?Nah BAS, pointless exercise, she's a woman!
They don't understand practical stuff, so I carry a torch, also just in case power goes off too.
