- Joined
- 10 Jun 2012
- Messages
- 52
- Reaction score
- 0
- Country
Hi all
I have recently replaced a single plastic socket with clipped 2.5mm T&E in my garage with 2 x metal sockets, 20mm conduit & 4mm T&E (very close to one another). This was changed as it was picked up on a PIR as non-compliant (no mechanical protection) and I wanted an additional socket.
I now require an additional double socket on the opposite wall.
By far the easiest way would be to continue the radial circuit up the wall, across the ceiling to the opposite wall and down to where I want the socket (about 1M up the wall, 2M across and 1M down again).
The ceiling is unfinished, and I believe that mechanical protection would not be required for the ceiling part - I understand that clipping to rafters will be fine (and running conduit up there would be a pain). But I will require conduit from the existing socket up to the ceiling and down from the ceiling to the new socket to maintain the protection
So, my question: How is the best way to cope with this transition from conduit to non-conduit?
I could just stop the conduit at the ceiling and continue the T&E out the top into the ceiling leaving a 'raw' edge. However, this seems like a bad idea - if there was a small leak it could drip down into the conduit slowly filling it up...
Seems like I would need something like this:
http://www.cable-connectors.co.uk/75007-size-2-cable-size-4.0-6.0-t-and-e.html (although annoyingly that is the only 4mm one I could find)
Mechanical protection seems very open to interpretation so it is difficult to find a definitive answer.
What should I do?
Thanks in advance
Kevin
p.s. I realise that one should should singles with conduits, however advice on these forums seems to be that for runs like mine T&E is acceptable.
What should I do?
Thanks in advance
Kevin
