Hi Again.
Yes I am "keen on the aesthetics of conduit" as I just think it looks the part for my workshop. I know it would have been quite a bit easier just to clip t&e to the wall but, whilst it may be a compliant solution, i think it looks poor. This way I have all the 2G boxes at eaxctly one height and all the saddle clamps exactly the same height ...very sad I know, but I like it!
My original concern was about cramming 2-off 2.5mm^2 T&e into one conduit as the MK 2 gang boxes I have bought only have one knock-out, and are fastened to the wall, though on closer inspection there is quite a bit of room. Don't forget the drops are only 800mm max.
The other issure was sealing the conduits against dirt and dust ingress, and I am not sure I have an answer other than add a blob of silicon.
Even know I don't fully appreciate why I shouldn't remove the sheave from the t&e as it still will be protected by the conduit.
If I do pass the t&e down the conduit I have gained 'triple' mechanical protection against an obvious loss of air gap.
What's the difference between baring back the sheaving for a short 800mm run and using singles throughout from the outset?
If I do bare back I guess I can use the conduit factors shown at http://www.tlc-direct.co.uk/Book/4.5.3.htm which shows i'm well in even if I count all 6 wires (2xL, 2xN, 2xE). i.e. 6x30 = 180 which is<460
