How much warning do people need ... Isn't this common sense?
You wouldn't light a fire and burn waste when your neighbour has their washing on the line and the prevailing wind is taking the smoke their way (unless you don't get on
) ... Should garden incinerators come with warnings telling us not to do so, or that they get hot and may burn etc?
Therefore, if you are spraying fine mist around it is going to go where the prevailing breeze takes it (unless you take precautions) and the same rules of plain common sense apply.
Perhaps shop staff could be trained to ask questions in order to identify stupid people and refuse to sell them the product if they fail the test
I'll start us off ...
Q1. This product produces a fine mist, which of the following apply?
a. Windscreen wipers should be used at all times on the intermittent setting and washers may be used as required.
b. Dipped headlights should be used together with the high intensity fog light (if the operator is especially dense).
c. Umbrellas, goggles and dust masks should be issued to everyone in the vicinity.
d. Precautions should be taken to prevent the mist causing damage to adjoining property.
