Sorry but this is simply not true. A good PVA glue, combined with screws, is far stronger then the wood itself. Durability, draught exclusion, weather sealing, insulation, noise transmission, resistance to cupping, are all no worse (or even better) with a planted stop, assuming the final assembly has the same dimensions as a solid casing.Sorry, Gerry, but you are wrong there. They are less strong.
