darn, you caught me!
So many options i'm not sure whats best.
I'm now sure i'm going to have to build a stud wall in front of the existing wall but Metal or timber?
The gypliner universal doesnt require me to level the wall 1st & studs will be true.
but it requires me to use thermaline board to get insulation which will encroach into room further than timber & inserted kingspan.
If i build timber studwall i can insert the kingspan or celotex as mentioned in earlier post & board over with foil backed but i always find that the timbers are never perfectly true.
My next questions are:
Timber
Should i use treated wood in case it should absorb moisture in formed cavity?
What gap do i leave between framework & wall? want it as close as possible as half the wall is exposed brickwork & half still plastered?
Do i vapour barrier over the warm side of the studwork i.e just before screwing up boards?
Use foil backed boards?
Do i lay a damp proof membrane over the concrete floor before building studwork so the woodwork is not directly on the concrete floor?
Metal gypliner Universal
Can i insulate between the metal studs so i can use a smaller thermaline plus board?
Will the metal studs, being hollow make putting insulation between studs pointless?
Can the metal frame support the window board? part of the board will be supported by the brick wall but the front edge will overhang the metal frame & board, this worries me that a heavy relative may see the window board as a nice seat & sit on it bending the whole frame?
Type of insulation
On a slightly different topic i'm not sure of the best insulation to install in the walls but also between the ceing joists.
Seen on holmes on homes they use a type of rockwool slabs that is cut to friction fit between the joists that gives thermal, accoustic & fire insultion.
Whatever it is they use is non itch as they are not wearing gloves or masks?
Was planning on buying rockwool from selco or jewsons but read that its still an irritant?
thanks for all the help & wont duplicate on another post.
