Apologies for the long post, just want to explain fully!
I have 2 lights in my kitchen, one over the main kitchen area and one in the diner area. Both light fittings are dimmable and have 6 halogen bulbs in each fitting. Fitting and dimmer switches were put in about 3 years ago and not touched apart from bulb changes.
About 2 weeks ago I turned on the kitchen area dimmer as usual and one of the bulbs blew, tripping the circuit as has sometimes happened before.
I reset the RCD to see which bulb had blown but no bulbs came on at all (The diner fitting was fine). Thinking there was a fault with the fitting, I swapped a couple of (knowingly working) diner bulbs over to the kitchen fitting to try to prove that theory and as expected, nothing happened. So, I took a good look at the kitchen light to see if a wire was loose but all looked and felt normal.
I decided to switch the wires around in the double dimmer switch and then the kitchen one worked, but the diner one didn't - making me think that the switch must be at fault, as both lights operated (but not together - are you following this? haha!)
So, I got a replacement double dimmer today, wired it up as it was wired PRIOR to me rewiring it the other way around (I had it all written down before I touched it, just to be sure) and the same thing has happened - it will only operate one light.
I'm guessing there is a fault with the wiring at the switch, but cannot understand how it's occurred as nobody touched the wiring prior to the fault - no decorating has been done to loosen the switches or anything.
Wiring as follows:
Kitchen side - red with white sleeve to common
- black with red sleeve to L1
Diner side (this is also operated on another switch by back door, but that hasn't been touched either) Red to common
Blue to L1
Yellow to L2
There are earths screwed into the metal box and also the metal dimmer.
Any ideas really appreciated! Thanks
Wiring as follows:
Blue to L1
Yellow to L2
