Double dimmer switch wiring nightmare!!
if you answered my questions we could have resolved this already..
the squiggle with the arrow through it is the output of the dimmer.
You give up too easily. The secret of fault finding is to break a complex system into sections. With power off, temporarily connect the brown, black and grey wires together at the switch end with choc-block. When you put the power back on, both lamps should light. If they do, you have a switch problem. If not, you've made a mistake in the ceiling rose. :cool: :cool: :cool:
Indeed, Space cat. That's what I suggested in my previous post.
Given that the O/P had the correct diagams for the switch and CR, he was almost there.
Oh well.....
Lucia.
the switch looks wrong to me.. as I've already said..
the ~ with an arrow through it is the dimmed output..
L2 is for 2 way.
depending on what make and model the dimmer switch is it may be a simple turn and push jobbie, in which case it shouldn't really matter, or it could be a touch / IR remote dimmer, in which case the way you connect it is cruicial..
