Double Glazing Help
24 Feb 2011
Glasgow
Hi Guys,Girls,
I had a new double glazed upvc patio door and bedroom window installed last year ( May). My apartment has never been so cold now. I am experiencing a cold stream of air in both my lounge amd bedroom.
I removed a plug and cold air is circulating just below the window behind the wall.
My older patio door and window were actually warmer.
Could the installer have forgotten to put any type of insulation around them. Also I can hear outside noises very clearly when the window and doors are closed.
Any ideas?
Sounds like they haven't been fitted correctly. Is the sound and cold air coming from underneath the patio door/window by any chance?
What does the sealing around the window outside look like?
Hi roofline,
Yeh the cold air is coming in at the bottom of the patio doors, just where the right hand door slides into the left one.
I checked the seals outside but they seem fine.
Do you think I need would need to get them re-installed?
Your windows and doors should be sealed properly inside and out.
The new ones should definately be warmer so I think there is an issue somewhere, but don't think it will be as dramatic as getting them re-ffited.
Is the company who installed them still trading? If they are give them a call, it sounds like a genuine complaint and they should send someone out to check the sealant etc.
