an open bathroom window allows bathroom moisture to be *pulled* into the home, working against Aim. Fan won't.
Totally agree with the points made about a bathroom fan. I have one but it's yet to be fitted up. Will fit when bathroom is redecorated in summer. I note however that the severity of condensation on the lounge patio door frames when we get up in the mornings doesn't change noticeably whether we've had morning or evening baths/showers the day before so I don't think much moisture is travelling around the place.
DO YOU HAVE TO MOP UP CONDENSATION PRIOR TO GOING TO BED?
No, I don't need to mop up condensation although the inside window frames are starting to get wet when we turn in. In the morning however, there's considerably more condensation on the frames and it's soaked into the tissue I place at the bottom of the patio doors the night before.
Our main condensation problems are not in the kitchen or the bathroom, although there is some condensation on the inside window frames in both these rooms when outside temp drops below about 3 or 4C - it's not too serious though. The main condensation is on the lounge patio door frames. These frames feel very cold to the touch (although that can be deceptive) but I think this indicates that the patio doors have a particular problem with cold-bridging.
Been watching the humidity/temp detector (also has max & min function for both relative humidity and temperature) positioned in the lounge. Over last few days, relative humidity has stayed in range 40 to 50%, 24/7 despite the very wet weather. Room temp has stayed within range 15 to 21C. Outside temp has been in range 0 to 11C.
From all sources I've now seen, there is no definitive ideal relative humidity level in domestic rooms. Figures I've seen for the UK suggest a range from about 30% up to around 55%, all year round assuming room temperatures of around 20C. Very few sources quote figures outside this relative humidity range.
Assuming my relative humidity measurements are reasonably accurate (I've no reason to think otherwise) then humidity levels in my home are acceptable, therefore condensation forming on window frames - especially on the lounge patio doors - is predominantly a cold-bridging issue due to a room with average humidity cooling down overnight and contacting the extremely cold internal patio door frame (the air 'trapped' behind the lined curtains that cover the patio doors is likely to have cooled more than the air in other parts of the room).
