You may just as well have done that to the double socket that was already there.plenty of room to drill a hole and feed that flexible cable in behind the socket through one of the metal box glands.
Then don't just drill a hole and poke the flex through to whatever.It may be my own home but I am not into doing a cowboy job, leave that to the initial builders thank you.
No it won't. The problem is drilling a hole and poking the flex through.
Why are you here if you know so much?
It compared exactly to what you said you intended to do.
Yes.If I do it your way, is it ok to spur off the 45A Cooker outlet plate with 2.5mm t&e cable to the 13A single socket? Thank you.
Yes.
Be aware the dual back box is slightly wider than the double.
