The electrician will test and inspect the relevant circuit which should show signs of a problem. An Insulation Resistance test will probably help pinpoint the issue.
Please do not continue to use that circuit. Turn off the MCB or take out the fuse (with caution) and call an electrician to repair the damaged cable. This is a serious risk even though the nail has been removed!
