If LED strips need say 40 watt, would doubling up two 25 watt transformers do it? That is 230v in on both and the 12v outlets commoned up.
You need DC power supplies. Doubling up two will likely create circulating currents due to a slight voltage difference on their outputs.
Do you get circulating currents by doubling up DC power supplier
Would you call that Circulating Current thoughIn most cases one of them, the one with the highest output voltage, will provide the majority of the current. A few millivolts difference between output voltages is all that is needed for the current sharing to fail. That said there are DC power supplies designed to operate in parallel mode. Low ohm reistors in series with the outputs will omprove current sharing but at the expense of having to use remote sensing. Taking the control feedback voltage from the load and not at teh piwer supply outputs.
Connecting the outputs of two Switch Mode Power Supply ( SMPS ) modules in parallel is very risky, They are very likely to go unstable and fail to control their output voltages correctly.
I think I can summarise this thread by saying "no"If LED strips need say 40 watt, would doubling up two 25 watt transformers do it? That is 230v in on both and the 12v outlets commoned up.
However to say can't ever be done would be wrong,
I wouldn't. "Circulating current" implies that there's current flowing out of one supply and into the other which won't be the case.Would you call that Circulating Current though
Even if they don't literally have 'diodes on their output, there has to be some rectification (with or without subsequent semiconductors) - so I would think it doubtful that there would be a significant 'backwards' path from the output. However, as bernard has said, 'applying a voltage' to the output might possibly play havoc with the regulation (if it is sensing voltage at that output).If the voltages are slightly different it could be the case. But if they have diodes on their output it won't happen.
