Downlight bulb replacement
Hi All,
I managed to sort his over the weekend. Unfortunately the bulb had go stuck in the fitting so I had to remove the whole fitting via the loft and gently tap the bulb out from behind using a hammer.
The bulbs are indeed GU10's but also require a short turn to remove.
Thanks very much to all that posted, your advice was appreciated greatly :cool:
Red
