Putting some downlighters in my ceiling and have a couple of questions:-
1) The terminal blocks on the actual light fitting are too small to accept 2 cables (cable in and the one back out again to next light). Is it acceptable to use a terminal block in the ceiling for the 2 wires to go into then use a short piece of cable from the terminal block into the downlighter itself.
2) The instructions say do not earth, so I assume I just cut back the earth wire away from the twin and earth cable I have installed? Besides there is no terminal on the fitting for an earth cable anyway.
Many thanks in advance for your help
Neil
Neil
