GaryMo,
If the luminaries had been supplied as a kit with 2 core cable minus a CPC then it's a totally different story.
What if they had not been supplied by 2 core but had no earth terminal connection?
The manufactures instructruction regarding downlights normally state no cpc needed, as they are double insulated plus as they will be in a chain should not effect another lighting circuit. . I always do connect the cpcs up in connection blocks though.
I have plenty of Electrical Installation certificate.. Can I still use them - there is no room to put the 2nd RCD on it or do I need to get new one. Any recommendation for computer recommended certificate software.
You continue on another sheet and page number it.
Is there any electrical circuits in the bathroom to sup bond?
SPS
